New Exterior Trim Features
Vinyl, wood and even PVC.
Crane Performance Siding.Solid Core Architectural Essentials vinyl trims now include the Window Crown Molding and the Band Board, featuring an insulated backing for impact resistance and R-value up to 4.0. Window Crown Mold comes in 12-foot sections; Band Board features a 71/2-inch wide panel and comes 20 feet long. (800) 366-8472. www.cranesiding.com.
Revere Building Products.Six new vinyl exterior trims and accessories feature a smooth texture with a low-gloss finish and come in white. The line now includes a 5-inch fluted lineal; a 45-degree, 2-inch-wide bay/bow outside corner post; and one-piece fluted and one-piece beaded corner posts. (800) 548-4542. www.reverebuildingproducts.com.
Azek. One side of the Frontier Series cellular PVC trim board is textured with a rustic wood grain while the opposite side is smooth. The reversible board lays flat on either side for versatile installation. The trim comes in 5/4 and 4/4 widths in 18-foot lengths and both surfaces can be painted. Like the company’s original trim boards, Frontier Series boards can be thermo-formed, but heat may minimize or distort the textured pattern, says the maker. (866) 549-6900. www.azek.com.
LP Specialty Products. SmartSide trims now come in 2- and 3-inch widths in both wood grain and smooth finishes. The engineered wood trims are treated with a borate-based additive that resists termites and fungal decay. The trims can be cross-cut or mitered, feature square edges, and come preprimed in 16-foot lengths. (800) 648-6893. www.smartsideonline.com.
Heartland Building Products. Visionary Accents exterior trims come in six dark colors and are made using the manufacturer’s Therma-Fast Poly-Thermal Formulation that resists heat and fading. The line includes a 31/2-inch Window and Door Surround as well as 33/4-inch and 5-inch Outside Corner Posts. The trims are covered by a No Fade warranty. (800) 432-7801. www.heartlandsiding.com.
