TimberTech. Featuring post-cap lights, baluster-mounted accent lights, post-mounted accent lights, and stair riser lights, the DeckLites product line is a customizable low-voltage lighting solution to stylishly illuminate the maker’s decks. The post-cap and baluster lights are specifically designed to fit TimberTech’s RadianceRail and Ornamental Rail systems. Easy electrical connections let installers run up to 30 lights from one 300-watt transformer. DeckLites are sold individually so that homeowners and designers can create a lighting scheme that’s ideal for each deck. 800.307.7780. www.timbertech.com.
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
