Versatex. The maker’s new super-thick, low-maintenance PVC 6/4 panel eliminates the need to laminate multiple sheets to achieve thicker stock. The panel measures 11/4 inch thick and comes in 4-by-8-foot and 4-by-10-foot sheets, as well as nominal 10-inch and 12-inch boards. Custom widths and lengths are available with extended lead times. The panels’ fine cell structure is consistent through the center of the board, the maker says. This allows the material to cut and work smoothly, and is more attractive when the center of the board is exposed, such as through routing. 724.857.1111. www.versatex.com.
Exteriors & Roofing
Versatex PVC 6/4 Panels
More about Versatex
Find products, contact information and articles about Versatex
