Vertical Rainscreen and Cladding Support
Designed for use over exterior continuous insulation, ProChannel Ci-Vertical steel rails from ClarkDietrich support exterior wall cladding and create a ⅞-inch rainscreen.
Designed for use over exterior continuous insulation, ProChannel Ci-Vertical steel rails from ClarkDietrich support exterior wall cladding and create a ⅞-inch rainscreen. The hat-channel-type rails come with preassembled (screw and sleeve) Trufast Grip-Deck TubeSeal fasteners; lengths depend on the combined thickness of the insulation, WRB, and sheathing they need to penetrate. Rails are also available in a black finish for open-joint cladding. clarkdietrich.com
