For What It’s Worth
"The Journal's pick of curious, interesting and useful products."
Batching It by Kate O’Brien Builders and developers of small communities not serviced by municipal sewerage systems can provide efficient and pollution-free wastewater treatment for a reasonable cost, with this batch wastewatertreatment system. Chromaglass systems are available in seven standard sizes, from 500 to 12,000 treated gallons per day. How it works: Free oxygen is introduced, and aerobic microorganisms clean and clear wastewater of 85 to 95 percent of its suspended solids. Batch treatment, much like the process used in municipal waste-treatment centers, is used. The treatment cycles are timecontrolled and a preset volume of treated effluent is pressure-discharged, allowing for peak surges and requiring less retention time. As a result, drain fields do not get clogged, or polluted. The system is accepted by
