For What It’s Worth
The Journal's pick of curious, interesting and useful products
Framing with steel studs can be simpler and faster using Clinch-On Eliminator Tracks. The tracks serve as the top plate of non-load-bearing walls. Studs fit into precut holes along 8-inch centers (for both 16- and 24- inch layouts) and snap into the slot. According to the manufacturer, no other fastening is necessary. On standard height walls, studs do not have to be individually cut to allow for discrepancies in the floor or ceiling levels because the studs extend up through the track. The track has a built-in edge molding that eliminates the need for J- or L-bead on the top edge of the drywall. This molding also serves as the wall band for suspended ceiling tiles. If wall framing
Clayton DeKorne
