For What It’s Worth
"NEB's pick of curious, interesting and useful products."
Cedar Accents by Kate O’Brien Fancy cedar shingles add flash to a building’s design. Shakertown’s Fancy Cuts come in nine different patterns, either as individual shingles or 8-foot panels. Patterns can be mixed and latched. The 100-percent clear western red cedar may be stained before or after application, or left to weather naturally. For additional information: Shakertown, P.O. Box 400, Winlock, WA 98596; 206/785-3501. Slider Sealer Plastic weatherproofing pan creates a continuous seal under a door or window. Jamsill Guard is made from molded ABS plastic with an aluminum bonded surface. It is normally installed in a rough opening before a door or window is installed. Once the door or window is installed, he sill guard is not visible. Jamsill will fit most wood
