Concrete Repair Epoxy
Designed for concrete-crack repairs, Simpson Strong-Tie’s new line of structural epoxy products have an improved viscosity range, with accelerated cure times, and can be installed at temperatures between 40°F and 110°F, according to the manufacturer. The products have been formulated for retrofit and repair work in light-frame, tilt-wall, water treatment, bridge and marine, and other types of construction. An upgraded suite of dispensing tools and injection systems also helps make applications fast, easy, and clean. Contact a local distributor for pricing. strongtie.com
