Panel Improvement: Dryvit Outsulation RMD
Designed specifically for residential applications in all climates, Outsulation RMD features a drainage plane between the code-approved water-resistive barrier (WRB) and the continuous insulation component. Installers and homeowners will be pleased to hear that a transferrable 10-year moisture drainage warranty backs the system for added performance assurances. Outsulation RMD is mechanically fastened to a plywood or OSB substrate or with adhesive over lath.
Dryvit | 800.556.7752 |dryvit.com
Lauren Hunter
