Post-Frame Purlin Splice Connector
https://www.strongtie.com/
Simpson Strong-Tie says its PFPS24 purlin splice connector for post-frame construction keeps purlins in line along the entire length of a trussed gable roof and eliminates the need to offset and overlap members. The PFPS24 is available with minimum and maximum fastener options, depending on load requirements, for value engineering. Contractors can also reduce material costs with this connector because they can use shorter, less expensive purlin stock. strongtie.com
