Rod Coupler Anchor
Simpson Strong-Tie Titan HD rod coupler anchor
Designed to be used with a single-story or multistory rod tie-down system, the Titen HD Rod Coupler anchor from Simpson Strong-Tie is now available in a 1/2-inch-by-9 3/4-inch size with a head style that accepts 3/8-inch-diameter threaded rod. The manufacturer says the anchor is a fast and simple way to attach threaded rod to a concrete stem wall or thickened slab footing; installation requires no special tools, cure time, or secondary setting process. It’s code listed in ESR-2713 for both wind and seismic loading. strongtie.com
