Builders’ Show Product Picks, Day 3
More product finds from the International Builders' Show in Las Vegas.
Danze. Known for kitchen and bath faucets, the manufacturer has expanded into bath furniture, toilets, and lavatories. Its latest offering is the contemporary Ziga Zaga Collection of vessel sinks that feature a mix of oval and rectangular shapes. Made from vitreous china, the sinks are designed to be paired with the 30-inch freestanding Ziga Zaga vanity with Zebra veneer. 888-328-2383. www.danze.com. –Nigel Maynard
TimberTech. Featuring post cap lights, baluster-mounted accent lights, post-mounted accent lights, and stair riser lights, the DeckLites product line is a customizable low-voltage lighting solution to stylishly illuminate the maker’s decks. The post-cap and baluster lights are specifically designed to fit TimberTech’s RadianceRail and Ornamental Rail systems. Easy electrical connections let installers run up to 30 lights from one 300-watt transformer. DeckLites are sold individually so homeowners and designers can create a lighting scheme that’s ideal for each deck. www.timbertech.com. 800-307-7780. –Lauren Hunter
Wayne-Dalton. Utilizing Z-Wave wireless technology, the Home Manager provides easy access and management of a network of home controls, including lighting, HVAC, and security. Homeowners can easily configure the system, add devices, and create custom scenes via an on-screen wizard. Lighting, temperature, and lawn irrigation can be set up to maximize conservation. www.wayne-dalton.com. –Katy Tomasulo
Kohler. Offering discreet assistance, the Belay tile-in handrail subtly recesses into the wall. It is made of two aluminum extrusions, one creating the grip rail, and the other mounting flush to the wall. Belay comes in a standard 30- or 54-inch length, which can be cut to accommodate custom sizes. Five finishes are available. 800-456-4537. www.kohler.com. –Vicky Markovitz
Crossville. Echo glass tiles are made from post-industrial recycled content that ranges from 10 percent to 100 percent depending on color. Ideal for walls, countertops, and floors, the tiles are made from centuries-old techniques where the product is cast from translucent glass that is textured on the front and back. It’s available in 15 colors, three finishes, and five sizes. 800-221-9093. www.crossvilleinc.com. –N.M.
Redstone Custom Door. Relatively new to the U.S. market, this company offers custom sliding and folding exterior doors in wood and metal cladding, including copper. Doors feature laminated-veneer-lumber cores and veneer skins that result in stiles and rails that are dimensionally stable. Virtually any size, design, door configuration, and wood species are available. 801-708-7290. www.redstonedoor.com. –N.M.
LiteSteel Beam. Made from cold-formed, lightweight steel, LiteSteel Beams (LSB) combine the strength of steel with the workability normally associated with wood beams and headers. The LSB design incorporates two fully welded hollow flanges and a flat, thin web that combine for maximum structural performance and load-carrying capacity. Suitable as basement, garage, roof, and ridge beams; long-span headers; and floor and deck supports, LSB weighs only 7.5 pounds per linear foot and can be cut to length on the jobsite with a circular saw, and drilled, screwed, bolted, and nailed using standard professional tools. It is available in 12 sizes ranging in nominal beam depth from 8 to 14 inches. www.litesteelbeam.com. 877-285-2607. –L.H.
Tonusa. The cabinet manufacturer has teamed up with esteemed designer Fu-Tung Cheng to create elements, a contemporary line of cabinets that offer elevated design at a moderate price. Designed to evoke warm modernism, the line includes a variety of luxurious and sustainable materials such as Forest Stewardship Council-certified Plyboo bamboo doors, 3-Form resin sliding panels, and recycled aluminum cabinet boxes. The series offers flexible component layout, integrated accessories, and soft-close hinges and door runners. 626-961-8700. www.tonusa.com. –N.M.
Heat & Glo by Hearth & Home Technologies. Part of the company’s Modern Collection, the LUX60 is a 60-inch direct-vent gas fireplace for buyers who want to make a style statement. Instead of faux logs, flames originate from a sculptural burner of randomly placed stainless steel tubes, and LED lights in the refractory create yet another dramatic effect with or without the flames. A sealed combustion system keeps carbon monoxide, nitrogen dioxide, and excess moisture from entering the home. www.hearthnhome.com. –N.M.
Fi-Foil. GFP (Gas-Filled Panel) insulation is filled on site with argon, krypton, or xenon gas to provide an R-value up to 11. The product consists of two external foil/polymer laminates and internal aluminum metalized films; as gas fills the chamber, the product expands to form an internal honeycomb structure. The design and components address three methods of heat transfer: radiation, conduction, and convection. GFP is fiber free, does not off-gas, is mold resistant, and ships flat, the company says. 800-448-3401. www.fifoil.com. –K.T.
Lauren Hunter
