Clearly Clean. Add efficiency and limit waste and mess from paint cleanup with the patent-pending Peel-Away Paint Tray. The durable tray features a reusable hard substrate base with four built-in liners. When a painting job is finished, simply peel away the liner, drain remaining paint back into the can, and dispose of the liner. Made of 50% recycled material, the trays require no water for cleanup, and the liners use 50% less material than traditional tray inserts. Available in 4-, 7-, 9-, and 18-inch sizes. 860.646.1040. www.peelawaytray.com.
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
