Heavy Hitters
These little gadgets carry big burdens.
Mechanical Plastics. The “pop” you hear lets you know that Toggler SnapSkru self-drilling drywall anchors are locked onto the wall. The shock- and vibration-resistant anchors install with a screwdriver or a screw gun and feature a positive stop that helps prevent overturning. Designed for hanging bathroom accessories, light fixtures, electric boxes, and more, the anchors can hold up to 135 pounds in 5/8-inch thick drywall (per anchor with #8 x 1½-inch screws), according to the manufacturer. 914.347.2727. www.toggler.com.
WingIts. The patented WingIt grab bar fastening system can be installed in 10 to 15 minutes and eliminates the need to tear open walls, the maker says. ADA compliant, the stainless steel system can hold up to 1,000 pounds. It can be used in ½- or 5/8-inch drywall with bath liners, fiberglass tub surrounds, tile, marble, and stone, as well as various panels including plastic and faux marble. The company also makes a range of ADA-compliant grab bars. 877.894.6448. www.wingits.com.
