Air Apparent: Versa Kitchen Faucet Aerator
A low-flow kitchen faucet may not be essential, but Niagara Conservation says it can save homeowners more than they think. The Versa Kitchen Aerator can cut water consumption by up to 5,460 gallons per year and utility bills by $80 annually as a result of less hot water use. Features include:
  • A 1.5 gallon-per-minute flow rate
  • Patented pressure compensator for constant water output regardless of pressure fluctuations
  • A 360-degree swivel and easy push-pull to switch between aerated-bubble and needle spray settings
Two other available aerators include the Tri-Max, featuring a dial that delivers three flow-rate options, and the new Lead-Free aerator constructed entirely of ABS polyethylene. Learn more at itseasybeinggreen.com.
Lauren Hunter
