ETL. Featuring 54 spray nozzles and 30% more water pressure than other showerheads, the Oxygenics Storm offers a water-saving showerhead without compromising the quality of the shower experience. By infusing air into the water stream to reduce flow while maintaining pressure, the Storm showerhead’s patented design can use up to 70% less water than other brands, the maker says. The showerhead’s internal components are made of Delrin, a material similar to Teflon, to increase durability and reduce mineral build-up and corrosion. The Storm is also backed by a lifetime performance warranty against clogging. 800.344.3242. www.oxygenics.com.
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
