J. Aaron. Custom made from top-grade hardwoods, the maker’s wood countertops are available in 16 wood species including African padauk, teak, black walnut, zebrawood, and lyptus, and can be combined with an array of profiles; distressed, rustic, or standard finishes; and thicknesses from 11/4 to 51/2 inches. Hand-finished with polyurethane, the surfaces require little or no maintenance, the maker says, and are scratch-, stain-, heat-, and water-resistant. A mineral oil finish is available for countertops that will be used as cutting surfaces. 404.298.4200. www.jaaronwoodcountertops.com.
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
