Preview of products featured at KBIS
Acryline.
Measuring 21 inches high, the Immersion Bath is no higher than a standard drop-in bath, but a horizontal overflow located just below the rim edge allows the bather to soak in water as deep as 16 inches. This represents 3 inches of increased depth without having to create a larger tub. The Immersion Bath is available as a soaking tub, air system bath, or island version (shown).
800.794.4667.
www.acrylineusa.com. Grohe.
Sleek design meets high-tech control in the Ondus faucet. The three-hole design is engineered with the maker’s SilkMove technology, which uses an enhanced ceramic cartridge for precise control and long-lasting performance. Color choices include velvetblack, high-gloss moonwhite, and Grohe starlight chrome. A chrome ring around the base of the faucet and handles adds a touch of sparkle. The collection also includes floor- and deck-mounted tub fillers, and the AquaFountain shower system.
630.582.7711.
www.groheondus.com. TurboChef.
Appealing to busy homeowners and anyone who likes good food fast, the maker introduces its Single Wall Speedcook Oven. The 30-inch oven incorporates Airspeed technology, previously only available for use in restaurants, to prepare high-quality food up to 15 times faster than a conventional oven, the maker says. The oven features hearth-shaped sculpted doors, a premium stainless steel chassis, and polished aluminum handles. The doors are available in six colors. A color LCD interface and precise dial-control knobs maximize functionality.
866.543.6569.
www.turbochef.com. Priele.
The Kanagara Shower Spa puts a luxurious spa experience within any homeowner’s reach. Available in standing shower and tub models, the units are designed to work with standard 5/8-inch (½-inch ID) piping systems, and internal plumbing with no components behind the wall. Rough-in requires only two ½-inch male pipe threads. Pressure tested to 120 psi, the powerful shower uses a maximum of just 2.5 gallons of water per minute.
305.374.9000.
www.priele.com. Look for this article on www.remodelingmag.com to see more products debuting at the Kitchen & Bath Show in Chicago this month.
Web Extra — More Products
Laticrete.
Create a finished look for tile installations with PermaColor grout. The cement-based material is available in more than 40 colors that resist blotchiness, efflorescence, and stain-causing mold and mildew. Greenguard-certified for better indoor air quality, PermaColor grout contributes to LEED certification with low VOC content. Kevlar-reinforced for strength and flexibility, the material is suitable for both interior and exterior floors and walls, and requires no additives for use.
800.243.4788.
www.laticrete.com. Danze.
A graceful arcing spout and handle define the floral-inspired Bellefleur faucet collection. Both kitchen and convenience-sink faucets are available with a unique two-function pull-down spray spout. As an alternative to the pull-down options, a conventional high-arcing kitchen faucet is available with a brass vegetable spray. A complementary convenience faucet is also available. Choose from chrome or stainless steel finishes.
877.530.3344.
www.danze.com. Vent-A-Hood.
Designed for use over most professional cooking equipment, the ZTH Range hood features glass accents and a stainless steel rail. Three models, measuring 36, 42, and 48 inches wide feature a 600 cfm Magic Lung blower, while the 54-inch-wide model has a 900 cfm Magic Lung blower. These strong blowers are able to handle cooking equipment that requires 900 cfm or 1,350 cfm, respectively. A matching wall-mount duct cover, sold separately is available for 7-, 8-, and 9-foot ceiling heights or in custom sizes.
800.331.2492.
www.ventahood.com. Diamond Cabinetry.
A pantry, broom closet, and laundry room extension in one, the Utility Cabinet creates usable, easy-access storage in otherwise unused space. A large lower section serves as a home for brooms and mops or an ironing board, while the four shelves in the upper cabinet adjust to fit cleaning and laundry supplies, and more. The cabinet measures just 6 inches deep.
www.diamondcabinets.com.
