Three-piece construction of all Ukinox double sinks means the bowl is welded to the deck, unlike sinks that are stamped out of a single sheet of stainless steel. The sink’s strength and durability are bolstered by heavy-gauge 304 stainless with high chromium and nickel content (18% and 10%, respectively) for improved stain resistance. Multiple styles and bowl configurations are available, from petite one-bowl sinks for bar or prep areas, to large double-bowls. Cutting boards, bottom grids, and other accessories are also available. Ukinox | 954.776.0444 | ukinoxusa.com
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
