Lasertron Designer LED Stainless Steel Cabinet
Lasertron. Brighten up any bar area with a Designer LED Stainless Steel Cabinet. Customizable to any size, and featuring unlimited designer cut-out options, the exterior spaces. Since LEDs give off very little heat, the lighting won’t cause the cabinet to warm up. The cabinet is constructed of premium-grade stainless steel, and doors feature welded corners, rolled edges, and no external welds or screws. A brushed finish is applied to all exposed surfaces. Glass and mirror front inserts are available. 954.846.8604. www.lasertrondirect.com.
Lauren Hunter
