Moisture-Repellant Subflooring From Roseburg
Specialized coating keeps water from impeding the construction process
Keep framing crews productive even in wet weather with Roseburg’s RigidCoat subfloor underlayment. The sheet material is treated with a water-repellant coating to block as much as 40% of moisture absorption in situations involving rain, sleet, and snow. The coating extends from the top of the panel to the tongue-and-groove edges, and is backed by a limited lifetime products and performance homeowner warranty.
Produced from Douglas fir and other western species for strength and dimensional stability, the material is graded PS1 by the APA – The Engineered Wood Association. The veneer is fully sanded for uniform thickness, and is balanced to reduce panel warping. Floor covering can be installed directly over RigidCoat. Roseburg Forest Products | roseburg.com
Lauren Hunter
