Cabinet Light Installation Tool
True Position Tools Cabinet Light Jig
True Position Tools’ Cabinet Light Jig facilitates the installation of light wires within the structural panels of a cabinet while eliminating the need for a light rail or double bottom. The jig can be used to conceal wires and lights in panels as thin as 5/8 inch. The base model kit ($250), which works with strip lights only, includes a jig, drill bit, and case. Kits that also work with puck lights (starting at $300) include steel-body Forstner drill bits with a wave cutting edge and adjustable stop collar. For installing strip lights, you’ll need to use a router to create a channel. truepositiontools.com
