Easy-Install Valve System
Gerber designed its Treysta rough-in valve system, for tubs and showers, to work in a range of plumbing situations. The compact, brass-forged body has mounting holes, while vertical inlets allow for flexibility in the wall and installation next to a stud in PEX applications. Its mounting system and plaster guard with depth indexing were engineered for quick installation, says the manufacturer. Treysta accommodates back-toback installations and reversed hot and cold inlets. Pricing starts at $65 and increases depending on configuration. gerberonline.com
