Electronic Flood Sensor
The Fibaro Flood Sensor is the first flood sensor to be introduced to Apple’s HomeKit system. Equipped with gold telescopic probes, the Flood Sensor can detect water as soon as it appears, even on uneven surfaces. If water is present, an LED indicator and sound alarm will trigger to alert homeowners on their smartphone through the Apple Home app. The Flood Sensor also has a temperature sensor, allowing homeowners to check unheated areas, like a basement or garage, for winter problems such as burst pipes. Paired with Fibaro’s new iOS 10 app, the device can be controlled remotely through voice commands using Siri. The sensor is priced at $70. fibaro.com/us
