Labor-Saving PEX Valve
Plumbing solutions provider Keeney Manufacturing Co. has unveiled its No Crimp PEX valve. The maker says that the push-on, quarter-turn valve with a compression sleeve creates an installation identical to compression valves, without the need for special tools, by compressing the sleeve around the pipe as the nut is tightened. While the sleeve compresses, a split ring and internal barb keep the pipe round, and a double O-ring seal helps prevent leaks. Valves retail for about $18. keeneymfg.com
