Multi-Application Drain Pump
The Sanivite Drain Pump can discharge graywater away from a variety of fixture types up to 16 feet vertically or 150 feet horizontally, according to the manufacturer. The drain pump, which can be used for basement kitchens and baths, fits inside a cabinet and is designed to handle sinks, dishwashers, showers, and washing machines. It comes equipped with a pair of 2-inch low inlets on either side and an additional 1 1/2‑inch inlet on top, along with a vent connection. Built-in check valves handle the drainage from any sink or tub. The unit discharges wastewater through a 1-inch, 1 1/4-inch, or 1 1/2‑inch rigid pipe. The unit costs approximately $440. saniflo.com
