Products
Products JLC’s Products by Leland Stone Nifty Miter Box For small jobs, you might consider replacing your power miter saw with the J.D. Miter Box. This manually operated miter box has two fences that adjust independently of each other, and they’re covered in a nonslip material. Both fences are equipped with clamps to hold crown molding in position. You’ve still got to cut the crown “upside down,” but the open design of the saw allows you to make cuts from the back of the miter box as well as the front. The most unusual feature of this saw is its guide, which consists of a pair of magnetized steel posts that grip the saw during the entire cut. C o n
