Products
Products JLC ‘s Products by Dave Holbrook Hot Wiring An outlet device should not serve as a splice for the wiring in a continuous circuit; it should be tied in to the wiring via a “pigtail” from a common wiring terminal. Term-a-Nut Pigtail Connectors make it simple, combining a twiston connector, flexible lead, and spade terminal in a one-piece wiring solution. The connector eliminates wire stripping and forming, and provides neat, uniform splicing inside the box. The connector is sold by distributors in seven different size combinations; prices vary. Contact: Ideal Industries, Becker Place, Sycamore, IL 60178; 800/947-3619; www.idealindustries.com. Sword in the Stone Concrete work is hard and heavy. Wouldn’t it be swell if you could just pull up your stakes and go home? That’s the idea behind StakeSleeves, a
Dave Holbrook
Dave Holbrook is a freelance carpenter and a JLC contributing editor, in South Orleans, Mass.
