Products
Sliding Security Pocket doors save space in small bathrooms, but how do you lock them? With the Pocket Door Privacy Lock non-handed, reversible hardware that installs in a standard, 21/8-inch-diameter, 23/8-inchbackset bore. The lock latches automatically on contact with the jamb and opens with a simple push button. It retails for $16. Contact: L.E. Johnson, 2100 Sterling Ave., Elkhart, IN 46516; 800/837-5664; www.johnsonhardware.com. Rebar Made Easy Correct placement of rebar in a footing can be an awkward, timeconsuming task, but it’s essential. If you’ve been looking for a way to make this often tedious task go faster, check out the new ReBar Chairs, available in two different configurations for double or triple runs using #3,
