A Smart Solar Door Lock
The Brinks Home Security Array Deadbolt is a smart door lock that connects with WiFi to provide security and convenience. Since the system is cloud-based, the lock can be installed without adding a gateway hub or other additional equipment. Homeowners can control the lock remotely from a smartphone or smartwatch, or manually with the front touch keypad or a traditional key. The lock is powered by a battery system and a built-in solar panel. It will be available in the fall, for $250. arraylock.com
