Ceramic-Coated Door Hardware
Inox says that CeraMax, its new line of ceramic-coated door hardware, lasts many times longer than stainless steel. According to the company, the finish resists most solvents and chemicals, as well as deterioration caused by salt spray or oxidation (reportedly withstanding the ASTM B117 Salt Spray Corrosion test used to evaluate the relative corrosion resistance to salt spray or fog at elevated temperatures 85 times longer than stainless steel), and can endure high humidity and ultraviolet light for up to 5,750 hours without yellowing or losing luster. The hardware is hand-finished and available in glacier white, graphite black, or flat black. Pricing varies by hardware type, size, and color. inoxproducts.com
