The most impressive features of the Revolution Tilt & Turn window are the ones you can’t see. A simple turn of the handle lets the sash tilt in, swing inward, or shut securely with the multipoint locking system. Inside the frame, users can add Innergy rigid thermal reinforcements. Made from 20% bio-based resins, Innergy helps the Revolution window achieve an R-value of 7 or better. Deceuninck | 877.563.4251 | deceuninck-americas.com
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
