Fakro Skylights
Fakro skylights include a range of features that help eliminate common complaints associated with skylights and roof windows. A frame that’s twice as thick as others on the market creates a large thermal barrier to prevent heat transfer that may result in condensation on the interior of the window frame. Metal cladding is replaced with a polyester-coated exterior finish for the same reason. Inside the frame, deep-set glass and specialized gaskets allow water to drain onto the roof before it can condense on the glass. Fakro | 630.543.1010 | fakrousa.com
Lauren Hunter
