Long-span glazing systems find favor
These new systems are a dramatic way to marry a living area to a back deck or patio. The challenge is making sure they're correctly installed.
9 MIN READ
When Jeld-Wen sales manager Brent Adair retrofitted his San Diego home with one of his company’s long-span folding door systems last year, he expected it to be an oddball job. The product, which the company introduced a year ago, wasn’t conceived with existing homes in mind. But that hasn’t stopped remodelers from using it. “When we initially came out with this system I thought it would be used only in new construction,” Adair recalls. “As it turns out, half of our jobs have ended up being retrofits.”
But although remodelers have warmed to these products, everyone we talked with for this article agreed that a retrofit can pose a real challenge. Door companies and installers alike said that any skilled contractor can install one of these systems, but that the job demands more care than the installation of conventional doors and windows. Part of the challenge comes from the need to assemble the various components on site, while another part of it comes from the framing requirements, which are more stringent than for nearly any other glazing system.
UNDERSTANDING THE PRODUCTS Long-span door systems can create a clear-span wall opening up to 24 feet long and 10 feet high. Homeowners have always had the option of having either a wall of glass or a long opening uninterrupted by posts, but until three years ago someone who wanted both had to choose between two niche companies. Now, they can choose from a growing list of big-name door- and window-makers.
The appeal of these systems should come as no surprise. As demand for outdoor living spaces continues to grow, especially in mild climates, so does the market for large openings. Long-span systems are the pinnacle of this trend, in that they meld inside and outside into one continuous space. The system that Adair installed in his home was a relatively small one — 12 feet long with four folding panels — but it has changed the way he uses his living area. “When the doors are open, they literally are able to double the size of my living area because the inside flows out to the back. It’s more of a wall that opens, than a set of doors.”
These products aren’t for the budget-conscious. The manufacturers interviewed for this article gave an average price range of $800 to $1,200 per running foot for a dual-glazed, 8-foot-tall system with pine frames painted in stock colors. Lead times tend to be about six weeks. Taller panels, different wood species, or better glazing will raise the price and increase the lead time. So will a retrofit that requires custom-sized panels.
These systems are available in folding and sliding varieties. Folding systems hang from a single track attached to the structural header. They typically consist of two banks of door panels that open to the left and right. When closed, they present a flat surface; when opened, the panels fold against one another, accordion-style, and stack flat against either end of the opening. Some manufacturers offer an “everyday door” option in which one of the doors at the center of the opening is hinged to the door next to it in such a way that it can be opened and closed like a standard hinged door, for everyday use.
In a sliding system — also known as telescoping or multi-slide — each door has a set of bottom rollers that ride on a metal track. Because each door in a sliding system travels in its own plane, the more doors there are, the wider the track must be. For instance, an eight-panel system will have four doors on each side, requiring a track more than 10 inches wide. When closed, the doors in a sliding system “step” from the ends of the opening to the center, with the end doors being closest to the home’s exterior.
Although doors sit snug against the track when closed, pulling on the door handle lifts the first door up, making it easy to slide. As the doors are pulled open, a coupler on each door grabs and lifts the next door. When fully open, the doors stack up parallel to one another at either end of the opening. The contractor also has the option of creating pockets at either end of the opening, into which the doors disappear. In these cases, the last panel can be fitted with a follower skirt — usually a piece of wood matching that used for the doors — that closes off the pocket.
One feature you can get with a sliding system that you can’t with folding doors is a motorized belt drive that will quietly open and close the doors at the touch of a button. As an example, Vista Pointe Architectural Systems’ co-owner and vice president of operations Dave Stevenson says that his company’s motor accessory consists of a steel-impregnated, toothed rubber belt that runs in the track above the door panels, and that’s attached to a pulley on one end and a motor assembly on the other. To accommodate the motor, the framer needs to add an extra 10 inches of length to the pocket beyond the depth needed for the panels. The cost is about $4,000, regardless of system size. Stevenson insists that the doors are easy enough to operate without a belt drive, and doesn’t recommend it unless the panels are very large or the homeowner has strength problems or a physical disability.
As for weather resistance, some contractors recommend always placing these doors under a substantial roof overhang. Manufacturers say that’s not necessary but add that not all door systems perform equally when subjected to water. A folding system with a weather-stripped, stepped sill will have the best performance, but many sliding systems are just as tight. For instance, Dave Koester, a brand manager at Weather Shield, says that his company’s telescoping door has a design pressure rating of 50, which means that it won’t leak when subjected to windblown rain that hits the door with a pressure of 50 pounds per square foot. That’s good enough to meet code in most coastal areas.
