New notable products for home remodel
ART MEETS TECH
Inspired by the combination of organic and mechanical features, designer Eric Kaster created the surreal Calliope chandelier. The light’s construction features 100% recycled cast aluminum clips attached to steel struts. Each of the 146 clips holds a colorful rectangle of art glass, creating a multifaceted lens. Customers can specify their art glass color preference. Incandescent or 4-pin compact fluorescent lamp options are available with an LED option coming soon.
Eleek.
503.232.5526.
www.eleek.com. CRYSTAL GATEWAY
Inspired by the intricacy of handcrafted quilts, the sparkle of jewels, and the artisanship of antique iron gates, Ventura doorglass and sidelite sets feature deeply beveled glass accented with faceted red and clear Strass Swarovski crystals. Rich patina caming finishes the look of this limited-edition design. Each set is numbered by the designer and includes a 24½-inch-by-65-inch doorglass unit, two 8-inch-by-5-inch sidelites, and a 66 7/8-by-33¼-inch half-round transom.
ODL.
800.253.3900.
www.odl.com. HOT HANGOUT
Ideal for high-rises, lofts, or any area where venting cannot be installed, Radium and Scandium catalytic vent-free gas fireplaces are designed to hang flat on a wall. Radium (shown) measures 35¼ inches wide, 27 inches tall, and just 7½ inches deep. Scandium is 41½ inches wide, 21 inches tall, and 7 inches deep. Catalytic converter technology cleans the hot air as it leaves the combustion chamber, so no chimney or venting is required.
Lennox Hearth Products.
800.953.6669.
www.lennox.com. SCULPTED STEEL
A complete line of door and cabinet hardware, the Ergo series is cast in stainless steel and polished by hand. Certain areas are sand-blasted for a two-tone look. The line includes door and cabinet pulls, entry door locksets, levers, locks, thumbturns, and more.
Martin Pierce Hardware.
800.619.1521.
www.martinpierce.com. GRATE EXPECTATIONS
The maker’s decorative metal grates are cast from postconsumer recycled iron, which makes up a minimum of 80% of each product. Available in numerous geometric, artistic designs, drain grates, trench grates, tree grates, and other custom items are all ADA-compliant and add a unique finishing touch to pedestrian areas, driveways, and other spaces.
Iron Age Grates.
206.276.0925.
www.ironagegrates.com. SHEETS OF METAL
Versatile wire mesh fabric from Cascade Coil Drapery can be used to create unique window treatments or room dividers, and can even be incorporated into wine racks and other furniture or cabinetry. Lightweight and easy to install, the woven-wire fabric offers light control and security, while still allowing visual freedom and the free flow of air and sound. The material is also flameproof and low-maintenance; cleaned with an occasional brushing or vacuuming, the metal-tone finishes will not fade or darken.
Cascade Coil Drapery.
800.999.2645.
www.cascadecoil.com. FOR MORE ABOUT PRODUCTS, VISIT EBUILD.COM, HANLEY WOOD’S INTERACTIVE PRODUCT CATALOG.
