ODL Severe Weather Doorglass
ODL. An updated line of Severe Weather Doorglass is engineered to withstand damaging weather conditions, such as hurricane and hail exposure. A high-strength aluminum frame has been redesigned with reinforced corners in a narrower profile with screw plugs flush to the door. The frame allows the door glass to fit into a standard door cutout and comes standard in powder-coated white that can be painted or stained. Severe Weather Doorglass does not require dealer-applied structural sealant. Because the frame is not bonded to the door, it can be repaired on-site if necessary. Certified for use in a range of door systems meeting Texas and Florida wind-borne debris requirements. 800.253.3900. www.odl.com.
Lauren Hunter
