Skylight Products
ODL. Roof Windows, featuring insulating glass and bronze tinting to reduce heat gain and increase energy efficiency, have been reintroduced to the market with vinyl frames. The new models are available in white with flat insulated glass or an acrylic glazing. Available in four sizes, the vinyl roof windows are made in fixed and operable versions. (800) 253-3900. www.odl.com.
Wasco. Ten architectural baked-enamel color frames that help provide a seamless roof appearance are now available on the maker’s full line of skylights, including the self-flashed E-Class unit with Ultraseal Flange. New colors include bone white, brick red (shown), black, Hartford green, aged copper, and Quaker bronze. (800) 388-0293. www.skylighting.biz.
Sun-Tek. Through only one opening in a roof, the Spyder Multi-Tube tubular skylight system allows natural light into multiple rooms in a home. The skylights come in 10- and 14-inch diameters and can be installed in double, quadruple, or mixed configurations. All configurations are for curb-mounted applications. (800) 334-5854. www.sun-tek.com.
Solar Innovations. Available in both aluminum and aluminum-clad wood, skylights from Solar Innovations are 100% thermally broken. Configurations range from double pitches, pyramids, and hip ends to barrel vaults and domes. An array of decorative options, high-performance glazings, and six standard Duracron colors is also available. Each structure includes pre-cut and assembled rafters. (800) 618-0669. www.solarinnovations.com.
Velux. Q Series self-flashing skylights are available in both curb-mounted and deck-mounted versions. The Q Series skylights feature a specially formulated, flexible, self-sealing EPDM synthetic rubber side flashing and integrated gaskets that eliminate the need for external sealants, says the maker. The self-flashing system is designed for easy installation. All models are available with the company’s Comfort Glass, ComfortPlus Glass, and Comfort Glazing + Blinds. (800) 283-2831. www.veluxusa.com.
Andersen. Low-E, impact-resistant glass for protection against wind-borne debris is now available on the seven smallest sizes of the manufacturer’s 400 Series skylights. The glazing features an inner pane of glass and a heavier, laminated outer pane. Options include Andersen’s PermaShield exterior cladding, corrosion-resistant hardware, and reinforced sashes, locks, and hinges. (800) 426-4261. www.andersenwindows.com.
