Soft-Close Door Hardware
Compatible with the company’s 200 Series I-Beam Track sets, Johnson Hardware’s 2066 Soft-Close Kit can support sliding doors weighing up to 330 pounds. When the hardware is used in single-direction, soft-operation pocket-door installations, doors must be at least 24 inches wide. For bi-directional installations, two kits are required and doors must be at least 32 inches wide. Each kit, available for $74, includes an actuator arm, dampener, track stop-block, adjustment wrench, and steel connection pin. johnsonhardware.com
