Composite Decking
MoistureShield expands its offerings with two new product lines
MoistureShield has added two new decking lines, one with an integrated cap and the other designed to stay cooler than conventional composites. Refine decking is made with a cap featuring high-definition wood-grain detail that provides fade, stain, and scratch resistance, according to the manufacturer. The Infuse line of decking also has what MoistureShield says is a realistic wood-grain finish. It absorbs as much as 35% less heat than conventional composites in similar colors, the manufacturer says. Both lines will be available as 1×6-inch nominal boards in lengths of 12 feet, 16 feet, and 20 feet. The decking is rated for ground contact and may be used under water without affecting its lifetime residential warranty.
Advanced Environmental Recycling Technologies, 479.756.7400, aert.com
MoistureShield Infuse
