Feeney Pre-Drilled Stair Posts
Feeney’s new pre-drilled posts and pickets eliminate the need to drill holes for the cables in the field, saving time and money and avoiding potential errors.
Feeney
Feeney’s new stair posts and pickets feature slotted holes that are drilled to minimize the size of the openings while maintaining angle flexibility. The pre-drilled posts are compatible with all of the manufacturer’s DesignRail Aluminum Railing top rail profiles, in base-mount, stanchion-mount, and fascia-mount configurations, using 1/8-inch CableRail infill. Three standard angle ranges and three standard railing heights are offered, with custom angles and heights also available. Posts and pickets include extra material at the top and bottom to allow for final trimming once the post locations are determined. Pre-drilled components include intermediate posts, threaded terminal posts (for the bottom of the stairs), Quick-Connect posts (for the top of the stairs), and intermediate pickets. feeneyinc.com
