Residential
SideJob Cargo Racks
Tired of humping sheets of plywood or drywall in and out of your van or pickup? Consider SideJob Cargo Racks. Mounted in less than a minute to the top rack on a truck or van, according to the manufacturer, the racks hold up to eight sheets of 1/2-inch drywall or a stack of 2x4s. Loads are secured with two nylon straps, and when you’ve unloaded on the other end, just pop the racks off and throw them into the back of your van. The racks can also serve as a kind of vertical workbench, holding sheet goods at eye level while you lay out cuts. SideJob Racks, 888.514.3592, sidejobracks.com
