Single Corner Post for Cable Railing
Feeney's DesignRail single corner post is engineered to replace the double corner posts typically required for most cable railing systems.
Feeney
A new single corner post for Feeney’s DesignRail aluminum railing system is engineered to replace the double corner posts typically required for most cable railings. According to the manufacturer, the new post is strong enough to withstand cable tension in both directions and is pre-drilled with horizontal slots that allow the cables to pass through a 90-degree corner (for an inside look at how the post was designed and engineered, check out the Feeney Features blog). The posts come with a curved lacing needle for feeding cable through the posts, and are available in base-mount, fascia-mount, and fascia-bracket-mount versions. feeneyinc.com.
