Residential
Wahoo Glass Panel Railing
Brackets allow water to drain
In the Wahoo Glass Panel Railing system, 4-inch-wide tempered glass panels with beveled edges are installed with brackets to aluminum top and bottom rails. All fasteners are hidden after installation, and wicking channels that are molded into the bottom brackets allow water to drain.
Railing-section kits are available in three lengths—4 feet, 5 feet, and 6 feet—and in 36- and 42-inch heights. Customers may choose between two tints for the glass: “twilight” and “pure” (shown). Stair brackets accommodate rake angles from 36° to 38° and come with pre-mitered glass panels.
Wahoo says the glass panels can also be purchased separately for use with other railing systems. Pricing varies.
Wahoo Decks, 877.270.9387, wahoodecks.com
Scott Gibson
