Engineered to hold the weight of standard beam construction, SkyLift Roof Riser Hardware is a solution for low-pitch or flat patio covers. Bolted to the home’s weight-bearing walls, it elevates the patio roof 24, 30, or 36 inches above the existing structure’s roof, increasing pitch to improve drainage and discourage debris buildup. SkyLift | 888.759.5488 | skylifthardware.com
Engineered-Wood Flooring Failures
6 MIN READ
A Look Back on Selling Remodeling Jobs
5 MIN READ
