Cordless/Hoseless Tools
The latest tools and accessories.
8 MIN READ
Ryobi
Ryobi
StoryID
501466
ToolNumber
1
ComponentId
tcm:78-1627349
Drill/Driver
Ryobi’s One+ Torque IV 18-volt drill/driver allows users to switch from drilling mode to driving mode with the flip of a switch, rather than turning a clutch ring. The compact tool has a center-handle design, a two-speed gearbox with variable speeds of 0–475 rpm and 0–1,600 rpm, 24-position adjustable clutch, 1/2-inch keyless chuck with spindle lock, and magnetic bit holder. The kit includes the tool, a flashlight, two batteries, and a one-hour charger. Price: $100. 800-525-2579. www.ryobitools.com.
Lithium-Ion Metal-Cutting Saw
Milwaukee has added four new products to its V28 line of 28-volt lithium-ion cordless tools–a 1-inch rotary hammer, a right-angle drill, a metal-cutting saw, and a jobsite radio–which offer up to two times more runtime and 40 to 50 percent more power than 18-volt tools at the same weight. The 0740-22 metal-cutting saw (shown) features a 6-7/8-inch blade that can cut 2-inch black pipe in a single pass, the maker says, and delivers 3,200 rpm. The saw features built-in motor overload protection, an LED light and clear blade guard for visibility, an all-steel shoe, and an electric brake. Price: Unavailable. 800-729-3878. www.v28power.com.
Lithium-Ion Hammerdrill/Driver
Part of Makita’s new LXT line of 18-volt lithium-ion tools, which offer the power of 18-volt tools with weights comparable to 12-volt tools, the BHP451 hammerdrill/driver boasts longer runtime and five times lower self-discharge than nicad 18-volters. The tool delivers 560 inch-pounds of torque but weighs only 4.9 pounds and measures only 9-7/8 inches in length. Features include three speeds, the Shift-Lock drive system for one-touch shifting from hammerdrill to driver mode, externally accessible brushes, an ergonomic shape, and two built-in LED lights. The battery communicates with the 45-minute Optimum Charger throughout the charging process; a built-in fan in the charger cools the battery to extend its life. Price: $590. 800-462-5482. www.makitatools.com.
Lithium-Ion Recip Saw
Metabo now offers lithium-ion batteries for several of its cordless tool models. The batteries offer 40 percent higher performance and 40 percent less weight than traditional batteries, do not have memory effect, and can be stored for up to 18 months with no self discharge, says the firm. The batteries are available with a full line of drill/drivers, a recip saw, and a rotary hammer; users also can upgrade existing BSZ Series tools to use with lithium-ion batteries. The ASE 18 recip saw shown here weighs 7.7 pounds and delivers 0–2,700 spm. It features tool-free blade changing, tool-free adjustable depth stop, a two-finger switch, and an ergonomically designed handle. Price: $414 (street price). 800-638-2264. www.metabousa.com.
Pivoting Screwdriver
A compact, pivoting body allows Ridgid’s 9.6-volt R81030 screwdriver to be used in pistol-grip or straight mode. The tool delivers 0–530 rpm and features an ergonomic two-finger switch, a die-cast torque-adjustment ring, a variable-speed switch, a 1/4-inch quick coupler, a die-cast gear box, and an overmolded handle. The tool comes with two batteries and a Rapid Max battery charger that charges in 20 minutes. Price: $99. 800-474-3443. www.ridgid.com.
Lithium-Ion Rotary Hammer
Bosch’s Litheon line of lithium-ion battery-powered tools includes ultra-compact 10.8-volt tools that perform a range of drilling/driving tasks and 36-volt tools that offer the power of corded tools in a lightweight, compact design. The first 36-volt tool in the line, the 1-inch SDS-plus Bulldog rotary hammer (shown) weighs 9.5 pounds, 15 percent lighter than a 36-volt nicad-powered rotary hammer, says the firm. It features a 7.2-amp motor that delivers 0–4,260 bpm and 0–960 rpm for 50 percent faster drilling. Other features include tool-free bit changing with automatic bit locking, an integral clutch to minimize torque reaction, a three-mode selector, variable-speed trigger, and 360-degree auxiliary handle. The battery pack includes cooling fins, vents, and electronics that help it withstand high-amp-drawing applications. Price: $700. 877-267-2499. www.boschtools.com.
Round-Head Framing Nailer
Hitachi’s NR90GR 3-1/2-inch gas-powered round-head framing nailer offers hoseless convenience with traditional framing nailer power, the maker says. The tool, which operates on a fuel rod and cordless battery, features dry-fire lockout, adjustable depth-of-drive, two-step nail-loading, and a rafter hook; a double-locking door keeps the fuel rod secure. The nailer fires up to 3-1/2-inch-by-.131 full round-head nails. The battery lasts for up to 4,000 nails per charge, and the fuel rod fires up to 1,200 nails. Price: $417. 800-829-4752. www.hitachipowertools.com.
Drill/Drivers
Designed for heavy-duty use, Craftsman black drill/drivers are powered by DieHard-branded nicad batteries. The line includes 12-, 14.4-, and 19.2-volt 3/8-inch and 1/2-inch models. They feature a two-speed gear box, a 24-position clutch, a single-sleeve keyless chuck, LED work lights, and T-handle body. Price: Unavailable. 800-377-7414. www.craftsman.com.
Drill/Drivers
The 15.6-volt SFH 151-A and SF 151-A cordless drill/drivers from Hilti deliver 619 inch-pounds of torque with 15 settings and feature all-metal gearing for a longer life and improved performance and a two-piece glass-fiber-composite housing for durability. The three-speed SFH 151-A accommodates bits up to 1/2 inch and provides for effortless drilling of 3/8-inch holes into masonry, the maker says. The lightweight, two-speed SF 151-A (shown) is ideal for drilling into softwood with a 1-inch auger bit. Both models include the C 7/24 30-minute charger, which has a refresh function that helps extend battery life. Price: $279–$369. 800-879-8000. www.us.hilti.com.
Framing Nailer
Paslode has enhanced its hoseless framing nailer to include a tool-free adjustable depth-of-drive for easy adjustments; a non-slip, over-molded grip; and a dual-position utility hook. The tool operates on a fuel cell and battery system; fuel cells drive up to 1,200 nails each and batteries drive up to 4,000 nails per charge. The nailer comes with a carrying case, rechargeable battery, charger, hex wrench, and safety glasses. Price: $379. 800-682-3428. www.paslode.com.
DeWalt’s new line of 36-volt lithium-ion-battery-powered tools offers the power of corded tools with similar or less weight than corded counterparts, the maker says, and delivers two to three times more runtime than 18-volt products. The 36-volt SDS rotary hammer shown here offers the same impact energy (1.9 foot-pounds) as corded rotary hammers, but with a weight similar to corded and 18-volt models. It provides a no-load speed of 1,150 rpm and 4,400 bpm and offers a 1-inch capacity in concrete with an optimal drilling range of 1/4 inch to 5/8 inch in concrete. Shocks Active Vibration Control, a system of shock absorbers positioned between the handle and the hammer, reduces vibration to the lowest amount in its class, says the firm. Other features include a compact L-shaped design for accessing tight spaces while maintaining balance, anti-slip grip, and side handle. Five additional 36-volt lithium-ion tools, along with a flashlight and combo kits, also are available. Price: $799. 800-433-9258. www.dewalt.com.
Hoseless Nailer
One of two new gas nailers from Powers Fasteners, the Powers Trak-It W3-34CDH drives paper-tape 34-degree offset round- and clipped-head nails with .250-inch-diameter heads. The tool has a lightweight, compact body size, the maker says, and includes two-step fuel cell installation and a five-tooth toenail. Price: $377. 914-235-6300. www.powers.com.
Hoseless Nailer
One of two new gas-powered hoseless nailers from Max USA, the Cordless Superframer GS683RH 21-degree plastic collation full round-head framer features a sequential trip trigger, no-mar tip, dial adjustable depth control, safety lockout, and one-step nail loading. The aluminum magazine has an open nose design for jam clearing; pointy teeth on the contact foot allow for easy toe-nailing. Other details for the 7.8-pound tool include a reversible belt hook and low-battery indicator. Price: $395. 800-223-4293. www.maxusacorp.com.
Hammerdrill
The Worx WT366K 18-volt hammerdrill from Positec USA features a full-metal keyless chuck and delivers 530 inch-pounds of maximum torque and 0–5,600 bpm/0–20,800 bpm. The tool’s drilling capacity is 1/2 inch in steel, 5/8 inch in masonry, and 1-1/2 inches in wood. The tool, which weighs 5.5 pounds, includes the company’s Ergosum ergonomic design technology. Price: Less than $250. 888-599-3711. www.worxpowertools.com.
Utility Knife
The QuickSlide Sliding Pocket Utility Knife from Stanley features a sliding blade holder that allows the user to open and close blades quickly and easily with one-handed operation. The knife accepts all standard utility knife blades and hook blades. Blades can be changed without tools. The knife has a slim design, the company says, and features metal construction and a one-piece belt clip. Price: $13. 800-782-6539. www.stanleyworks.com.
Floor Span Connector
New from Simpson Strong-Tie, the Floor Span Connector connects upper floors to lower floors from inside the wall, providing an alternative to coil straps and eliminating buckling, the company says. Installed on the side of the stud, the connectors do not interfere with drywall. The connectors have oblong holes for easier nailing in tight spaces; nails can be installed at a 30-degree slant with no reduction in capacity, according to the firm. Price: Unavailable. 800-999-5099. www.strongtie.com.
Pliers
Channellock’s new Code Blue line of pliers features laser-hardened teeth and cutting edges for longer life and easier cutting; PermaLock fasteners that won’t fail like traditional nut-and-bolt assemblies, the maker says; and high-carbon, drop-forged steel for strength and durability. The tools’ red-and-blue grips consist of a hard core covered by soft rubber for comfort and control. The line includes the 430CB tongue and groove, the 318CB long-nose plier, the 911CB cable cutter, and others. Price: $18–$29. 800-724-3018. www.channellock.com.
Kneepads
Custom LeatherCraft’s new G350 kneepads feature removable snap-on, snap-off caps: Use the durable, grooved hard cap for rough or outdoor surfaces; remove the hard cap to use the smooth inner cap for flooring and other delicate surfaces. The kneepads have an injected gel interior that moves with the knee for comfort, a breathable neoprene lower strap with double closure, and molded interior padding. Price: $50. 800-325-0455. www.clccustomleathercraft.com.
