Fall 2010 Hot Finds
Dual-Bevel Glide Miter Saw / Palm Nailer / Rotary Hammer / Impact Driver
Bosch
Bosch
MITER SAW
A revolutionary articulating dual-arm pivot system is the key feature of the recently unveiled 12-inch Dual-Bevel Glide Miter Saw (model GCM12SD) from Bosch Tools. The pivot system reportedly offers several advantages over sliding-rail mitering systems; one is a 24-inch-deep operating “footprint” that requires zero-clearance behind the unit yet provides a 14-inch horizontal and 61/2-inch vertical cutting capacity. The unique setup also offers smooth friction-free operation and reduced sawdust buildup on the arm’s articulating parts.
¦ Price: $799. 877-267-2499. www.boschtools.com.
CORDLESS PALM NAILER
Milwaukee Electric Tool Co. has added a professional-grade battery-powered palm nailer (model 2458-20/21) to its 12-volt cordless M12 line. Unlike other cordless nailers with angled heads, this unit is designed to be used with a hand-over-tool grip, like a conventional pneumatic nailer. According to the manufacturer, the new tool will be powered by next-generation “Red” lithium-ion batteries and has the capacity to drive both framing and joist-hanger nails.
¦ Price: $99 (tool only); $129 (with battery and charger). 800-729-3878. www.milwaukeetool.com.
CORDLESS ROTARY HAMMER
Hilti’s new rechargeable battery-powered rotary hammer (model TE 4-A18) has a high-efficiency motor and eccentric gearing that, combined with its exclusive warranted 18-volt CPC batteries, enables it to drill more holes in concrete per charge than any other cordless rotary hammer in its class, says the company. Features include a keyless chuck, variable-speed trigger, and drop-resistant housing. Two drilling modes, hammer-drilling and drilling only, add to the tool’s versatility.
¦ Price: $599 with two batteries and charger. 800-363-4458. www.us.hilti.com.
MULTIFUNCTION IMPACT DRIVER
A 12-volt cordless 3-in-1 Impact Driver (model RK2515K2) that operates in power drill/driver, screwdriver, and impact-driver modes has been added to Rockwell’s LithiumTech line of rechargeable lithium-ion tools. It delivers up to 900 inch-pounds of torque and has a no-load speed of 0-200 rpm (0-600 rpm in screwdriver mode and 0-3,000 impacts per minute in impact mode). The tool has an all-metal two-speed gearbox, variable-speed trigger with forward/reverse switch, 1/4-inch hex keyless chuck, LED worklight, and low-battery indicator.
¦ Price: $199.99 with two batteries, charger, carry bag, and hex bits. 866-514-7625. www.rockwelltools.com.
StoryID
1427571
ToolNumber
1
ComponentId
tcm:78-1629035
