Launch Time 2009: Greenlee Auger Bits
Tools from the STAFDA (Specialty Tools & Fasteners Distributors Association) Show
StoryID
1504514
ToolNumber
1
ComponentId
tcm:78-1629429
Greenlee
Greenlee’s extended-length (24- and 30-inch) auger bits eliminate theneed for bit extensions, which can catch on obstructions and prevent efficient chip removal. The self-feeding hardened-alloy steel bits have 7-16-inch hex shanks with quick-change grooves for use with impact drivers, resharpenable cutting edges, threaded screw points that draw the bit completely through the wood, over-center flutes for fast chip removal, and shafts straightened to reduce vibration. Price: $25. 800-435-0786. greenlee.com
