Tool Test: Cordless Circ Saws
Across the Board: These 11 cordless circ saws have come a long way in power and features.
19 MIN READ
Photo: dotfordot.com
BoschVolts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
1664K18/2.4/nicad 6 1/2 inches2 1/8 inches1 3/4 inches9.6 pounds
StoryID
571677
ToolNumber
1
ComponentId
tcm:78-1627956
Tester Comments
Ninth place in cuts per charge test, seventh in power test, unable to complete high-demand test. A mild performer, this saw would be best for light-duty cutting. This saw is large and heavy for an 18-volt tool and felt awkward, with a trigger handle that was too fat for comfort. A standout feature is the rafter hook. This was the only nicad battery tool in the test. Kit contains only one battery.
Street Price
$229
Contact
Bosch
877-267-2499
www.boschtools.com
nullnullnull
HitachiVolts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
C18DL18/3.0/LI 6 1/2 inches2 1/4 inches1 9/16 inches7.6 pounds
StoryID
571677
ToolNumber
2
ComponentId
tcm:78-1627956
Tester Comments
Sixth place in cuts per charge test, eighth in power test, unable to complete high-demand test. This tool is suited for a lighter-duty trim and siding work as it stalled out frequently when under much of a load. It tied for lightest weight, and was one of the most comfortable saws with nice balance and a great grip. Its cut-line light is a handy feature. A flexible fuel model, so it can use older nicad and NiMH batteries. Only available in a multitool combo kit.
Street Price
NA–in combo kit only
Contact
Hitachi Power Tools
800-829-4752
www.hitachipowertools.com
nullnullnull
Makita Volts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
BSS61018/3.0/LI6 1/2 inches2 1/4 inches1 9/16 inches7.6 pounds
StoryID
571677
ToolNumber
3
ComponentId
tcm:78-1627956
Tester Comments
Fifth place in cuts per charge test, fifth in power test, sixth in high-demand test. The best small saw in the test, with surprising power and runtime for an 18-volt tool–it powered through the tough stuff with ease. This saw tied for lightest weight, and had superb balance and the best-feeling grip. The cut-line light and blower and extra calibration settings are all advanced features that set this saw apart. Kit contains two batteries.
Street Price
$399
Contact
Makita
800-462-5482
www.makita.com
nullnullnull
MetaboVolts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
KSAP1818/2.2/nicad 6 1/2 inches2 1/8 inches1 5/8 inches9.8 pounds
StoryID
571677
ToolNumber
4
ComponentId
tcm:78-1627956
Tester Comments
Tied for last (10th) place in cuts per charge test, 10th in power test, seventh in high-demand test. This tool was generally a low-performing unit, but showed surprising backup power in the high-load test. The saw is heavy and bulky for an 18-volt tool, and its forward-tilted trigger handle design made it uncomfortable to use. The battery fuel gauge is appreciated, and its unique vacuum attachment port might be helpful for some indoor cutting. This tool has flexible fuel capabilities for both nicad and NiMH batteries. Kit contains two batteries.
Street Price
$389
Contact
Metabo
800-638-2264
www.metabousa.com
nullnullnull
PanasonicVolts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
EY3551GQ18/3.5/NiMH 6 1/2 inches2 3/8 inches1 1/2 inches8.7 pounds
StoryID
571677
ToolNumber
5
ComponentId
tcm:78-1627956
Tester Comments
Eighth place in cuts per charge test, ninth in power test, eighth in high-demand test. This saw performed on the lower end of the tests and was just barely able to complete the high-load test. This tool was not a comfort standout, and some of its features appeared lighter-duty than most. The metric-blade-only arbor on the saw made it difficult to find a replacement blade–a really big issue. This tool was the only NiMH-powered saw tested, and the saw comes with a giant combo kit case when ordered alone. Kit contains only one battery.
Street Price
$279
Contact
Panasonic
800-338-0552
www.panasonic.com
nullnullnull
CraftsmanVolts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
320.1719920/2.2/LI 7 1 /4 inches2 3/8 inches1 5/8 inches9.4 pounds
StoryID
571677
ToolNumber
6
ComponentId
tcm:78-1627956
Tester Comments
Tied for last (10th) place in cuts per charge test, last (11th) in power test, unable to complete high-demand test. This saw was outclassed by every other saw in the test and is not suitable for professional jobsite use. It stalled out constantly, because its large blade requires more torque than its 20-volt motor can supply; this often required a manual resetting of its battery overload switch. The cut-line light and battery fuel gauge are nice features, but the saw could do without the laser. Kit contains two batteries.
Street Price
$300
Contact
Sears Holdings Corp.
800-235-5878
www.sears.com
nullnullnull
RidgidVolts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
R88524/3.0/LI6 1/2 inches2 1/8 inches1 5/8 inches9.1 pounds
StoryID
571677
ToolNumber
7
ComponentId
tcm:78-1627956
Tester Comments
Fourth place in cuts per charge test, sixth in power test, fifth in high-demand test. This is a good all-around framing and trim saw with decent power, but it stalls out a bit easier than most. The balance and feel were notably good, and it was the only saw of its size and shape with a blade-right design. The battery fuel gauge is appreciated, but the lack of a blade brake is really noticeable for a pro-level tool. The saw is not sold in kit form, and although it can take 18- or 24-volt batteries, the 24-volt batteries and charger can be difficult to find.
Street Price
$377
Contact
Ridgid Inc.
800-474-3443
www.ridgid.com
nullnullnull
Milwaukee Volts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
0730-2228/3.0/LI 6 1/2 inches2 1/8 inches1 9/16 inches9.5 pounds
StoryID
571677
ToolNumber
8
ComponentId
tcm:78-1627956
Tester Comments
Third place in cuts per charge test, fourth in power test, fourth in high-demand test. This is a great saw that does everything very well, and it’s just behind the winner as an all-around framing and trim saw. This tool was almost impossible to stall out–cutting powerfully without binding–and has a very fast blade brake. It was among the best in balance and comfort. The battery fuel gauge is useful. Kit contains two batteries.
Street Price
$364
Contact
Milwaukee Electric Tool
800-729-3878
www.milwaukeetool.com
nullnullnull
Bosch Volts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
1671K36/2.0/LI 6 1/2 inches2 1/8 inches 1 5/8 inches10.5 pounds
StoryID
571677
ToolNumber
9
ComponentId
tcm:78-1627956
Tester Comments
Second place in cuts per charge test, third in power test, first in high-demand test. This is the best of the test, a great all-around tool that met all of our needs for framing and trim work. With unstoppable power, this saw never stalled out and even performed better when under the highest loads. This tool also has the top-rated balance and feel of a winner, and great features such as its rafter hook and battery fuel gauge. The saw can use a smaller 36-volt battery pack, which makes for less runtime but also for less weight. Kit contains only one battery.
Street Price
$329
Contact
Bosch Power Tools
877-267-2499
www.boschtools.com
nullnullnull
DeWalt Volts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
DC300K36/2.4/LI 7 1/4 inches2 7/16 inches1 5/8 inches10.1 pounds
StoryID
571677
ToolNumber
10
ComponentId
tcm:78-1627956
Tester Comments
This saw had an interesting mix of high-performance results and frustrating user experience. Even though it could cut super fast, its 7 1/4-inch blade didn’t leave much reserve torque, the saw stalled fairly easily at times, and the battery had a short life. The tool was uncomfortable to use, especially with its hard edges around the trigger. The tool-less blade change was clumsy, and the blade even came loose during normal use. Kit contains only one battery.
Street Price
$379
Contact
DeWalt Industrial Tool
800-433-9258
www.dewalt.com
nullnullnull
Hilti Volts/Amp Hours/BatteryBlade SizeDepth of Square CutDepth of 45° Cut Weight as shown
WSC7.25-A3636/3.3/LI 7 1/4 inches2 5/8 inches 1 7/8 inches12.3 pounds
StoryID
571677
ToolNumber
11
ComponentId
tcm:78-1627956
Tester Comments
This is high-performance framing saw that could replace a corded saw on the jobsite for most uses. Its runtime was the longest, cutting all day on two charged batteries. Built like a corded saw with a blade-right design and a 7 1/4-inch blade, it was bigger and heavier than the others but could stall if pushed hard. The weight was the biggest drawback, and the saw was difficult to use with one hand. The battery fuel gauge was nice, and the rip fence was the best. Kit contains only one battery.
Street Price
$499
Contact
Hilti
800-879-8000
www.us.hilti.com
nullnullnull
Michael Springer
Steve Veroneau
Steve Veroneau is a custom framer and is a contributing editor to Hanley-Wood's Tools of the Trade.
