Tools from the Remodeling Show 2011: Tapco Anniversary Brake
StoryID
1750361
ToolNumber
1
ComponentId
tcm:78-1630222
John Miller of Tapco Tools used a short version of the Anniversary Brake to show me how to make a number of different flashings: sill pans, head flashings, and a brick mold trim for use with replacement windows.
Using a brake to make a custom pan flashing
Using a sheet metal brake to produce custom head flashings
Bending a brick mold casing
The Anniversary Brake was introduced on the 50th anniversary of the invention of the portable brake. This new model sports several improvements to the original design: removable handles, jaws that open wider than normal, and a “hinge” that works by means of cams instead of the usual piano hinge. In addition to using the brake, Miller made use of a removable slitter and a Brake Buddy.The Brake Buddy is a hand-held roll-forming device that can roll various profiles into sheet metal – it’s very slick.
See videos below
David Frane
