Tool Test: Framing Nailers
Look for a gun that toenails well and can consistently set fasteners in dense material
8 MIN READ
Favorite Models
Over time, the carpenters on our crew gravitated toward the same three framing guns. In descending order of preference they were the Paslode, the DeWalt, and the Bosch.
Paslode’s gun feels powerful in use and came out on top in our nailing test. It’s lighter than average and has a comfortable contoured grip and trigger. The metal rafter hook pivots to several positions and is wide enough to fit over thick engineered framing members.
With its comfortable grip and trigger, the DeWalt was a crew favorite. The board hook pivots freely and will fit over thick framing material, and the push-button depth-of-drive mechanism is very easy to set. Although not particularly light, the tool is well-balanced and easy to handle.
The Bosch proved its power in the field and was the No. 2 model in our nailing test. It has a sharp aggressive nosepiece, a comfortable ribbed grip, and a quick-release magazine that makes it easy to clear jams. The slim piston housing makes for a very good view to the tip. This gun would have placed higher if it came with a board hook.
Tim McNamara is a framing carpenter and contractor in Rochester, N.Y.
Of the guns with rafter hooks, only DeWalt's (far left) and Paslode's are wide enough to fit over thick engineered material. The Makita's hook (left), while sturdy and made from metal, is barely wide enough to fit over 2-by lumber.
The thumbwheel on the nose of the Paslode (above) is typical of the depth-of-drive mechanisms found on most framing guns. The thumb-activated mechanisms on the DeWalt (right) and Bostitch guns are particularly easy to use.
A quick-release lever allows the Bosch tool's magazine to be removed without tools when clearing jammed nails.
